Parameters - batch create
I have multiple .prt files that need specific parameter information. At the time the project was started, we didn't have a start part with this information. Can I use the information from the param.inf file of one part and incorporate that into multiple parts? Any assistance is most appreciated.
Eholmes
RE: Parameters - batch create
Eholmes
In your model tree, show columns, in type go to model params, use the arrow keys to transfer all parameters across.
It's best to do this in the top level assembly as you can copy and paste parameters from models to other models. You can also use this to create parameters provided they appear in the top level model. Great way to add a new parameter to all the parts in an assembly!
Hayden
