Structural Analysis and Design Software
I am interested in structural analysis and design software for R.C. continuous beams. Software such as Staad or Sap are more oriented to 2d frames and 3d frames or plates.
Any suggestions?
Hasanh
Any suggestions?
Hasanh
RE: Structural Analysis and Design Software
I have come across very cheap software from Archon Engineering which includes a program called Wincrete which checks designs for RC Beams including multi-span. They also have nice programs for other structural areas. Their website is www.archeng.com
Mike
I have used software from CADS which comes in bolt together modules for structural steelwork, reinforced concrete etc. it is windows driven and engineer friendly. The website is www.cads.com
Ginger
Regarding Ginger's response, please confirm that www.cads.com is correct. The address does not seem to be relevant to our subject.
hasanh
Once again I have given the wrong website for a company. The website for Archon Engineering is www.archoneng.com
Its worth a visit. You can download a shareware version of all of their software programs.
regards
Mike
Thank you for your reply. I am checking the site out.
Many structural software companies give fantastic descriptions regarding their products. But when tested, they may not suit one's needs. Therefore, it is important that structural software companies allow downloading shareware versions for a limited time period.
Hasan
Apologies for the wrong address. CADS can be found on www.cads.co.uk Another avenue you may wish to try is the OASYS system by Arup. i don't have an address for their OASYS site but Arup are pretty easy to locate worldwide and someone there should be able to help you. Good Luck
Ginger
Please try www.avansse.com site.
They have very usefull and user friendly software. I am talking about AVwin and Gedi. Particulary Gedi will let you generate interactively all the parts of a concrete building.
I am a user of those programs and I feel very confortable.
Let me know your opinion after visiting the site, please.
Best Regards,
Carlos
I have come upon a nice program called prokon. It is very easy to use and based on British and South African Standards.
Hasan
I have used Prokon and its good and affordable. A more expensive option for design and detailing that it really worthwhile, (I thought anyway) is CADS 8110 - it is a structural analysis, design, drafting and detailing package I came across when I was in Singapore. I don't have a web address for them but they were marketted by a company called QE Design Systems in Singapore - Tel: 65 224 2883; fax no: 65 2218928
There is also an Australian package I foudn to be very good called SpaceGASS. Again I don't have a web address but if you search for SpaceGass you should find it easily.
Good luck,
Bridgeman
Has anyone out there tried TEDDS from CSC? It is a series of Calculation Pad for the Professiional Engineer. Any comment on the above software will be much grateful.
BengChin
please visit www.roynshenoy.com and click software. I have a very versatile software for RCC Columns, COLDES, which allows for Slender columns, subjected to biaxial Bending, different reinforcement percentages on adjecent sides, etc.
you may mail me for free version. roynshenoy@vsnl.com
<br>
I used to do these by hand in the 60's. In the late 70's I programed my own calc's in basic. Currently, I am using a spreadsheet approach to analysis, and seem to always be behind the curve in conforming to codes and standards.
I am curently reviewing the CSC TEDDS package. It is a good tool which works in Word for documenting calculations & code requirements. The initial interface takes some time to understand. I'd like to hear your comments on it's use & applications.
Get a copy of Staad3 and you'll be able to do anything with trusses as well as anything else using steel or concrete. Also, Enercalc makes a program called FastFram, which can be downloaded, free, from their site but they don't update it and there is a bug in it. Good luck!
I have come across a good software for design and analysis of concrete structures, i hope this software might be of some use to u, check it out at this site - http://www.zentech-usa.com/concrete.htm.
There are somemore, but they are either too much or too little for your purspose. I remember encountering a similar problem once, fortunately this s/w was enuf for my needs. check it out if it suits u too,
Sreevathsa
Check out a company called Keymark. I tested a beta program by Keymark, designing light gage steel trusses in 1994, which probably has improved greatly since than. When wood was getting expensive in the early '90s, we did a lot of light gage steel design for residential structures. They can be reached at www.keymark.com.
The main problem I have found is finding the time to learn how to use it effectively.
sc
http://www.structural-engineering.fsnet.co.uk/
i have expertise in modelling and analysing any type of structures using staadpro.
hi 2610, what version of STAAD are you using?
STAAD PRO2000 OR 2001?
HI,
THANK YOU FOR YOUR QUESTION.
I AM USING STAADPRO (VERSION III)FOR ANALYSIS PURPOSES.
TELL ME ABOUT ANY SOFTWARE THAT CAN BE USED TO ANALYZE OFFSHORE STRUCTURES.
Hi
Well, i dont know of any structural analysis software that would specially analyse offshore structures, maybe if you make a more detailed description of the structure you are dealing with,and the kind of analysis you want to do, i could help you. I guess that it has to do with structures subjected to impact loads from ships and sea wave loads. Maybe you could do all this with Sap2000, since this software is a little more powerful than STAAD III, and have better load generation capabilities.
I would like to know about your experiences with STAAD, since i also use that software. I would like to know if you consider it reliable.
ive just seen a very interesting site:
www.zentech-usa.com/index.htm
They have a Software called STRUCAD 3d
i think this software is what you are looking for....
It's very affordable compared to others mentioned .
Steel Smart System from ENR Solutions will do all kinds of light gage metal framing including trusses.
Here's a site that has Excel spreadsheets with various applications. I have gotten several of them and found them to be well written. Very professional use of visual basic macros.
http://www.mecaconsulting.com/
http://www.spiraleng.com
If you wish to visit my website, we can discuss these or other issues further.
THANKS BUT I COULD NOT FIND ANY CONCRETE DESIGN SOFTWARE.
I would check the Algor program. It has been used for offshore platforms.
Tony
ERNESTOBARRERA ,
thank you for the information. I have visited the site. really they have the software which I need. But problem with me is I can not afford to buy the same.
I am presently involved in dynamic analysis of offshore fixed platform, which has got about 120 members of steel tubes having varing diameters.
problem in ussing staadpro is that it can't just calulate wave forces by taking in to wave heights, wave period and depth of water.
i have a problem of analysing the structure for the wave and wind force for different wave heights and periods.
the MORISSONS EQUATION has to be used to calculate the wave forces on each members, which becomes tedious process for different wave conditions.
my structure is like a tower, submerged in deeep water.
i need help from indivisuals or company who can analyse the tower and supply me the resuls like natural period, deck displacements, which I am using to train NeuralNetwork for predicting the responses of towers.
this is my Project work for M.Tech (structures) at Regional engineering college.
keep in touch. thank you in anticipation of suggestions.
Ganesh Hegde
tonyriva,
Hi, i want to know more on algor Program.
my problem is explained in the abve reply to ERNESTOBARRERA
if it helps in getting me the resuls please let me know from you
thank you
Ganesh Hegde
For offshore structures you want SACS (www.sacs-edi.com). The analysis of offshore structures is quite involved so I doubt you will be able to find anyone to donate the analysis. Good Luck anyway.
Randy
Please check the Reinforced Concrete Council's website below:
http://www.rcc-info.org.uk/
They have many spreadsheets for concrete design to BS 8110 and Eurocode 2, including continuous beam design. The spreadsheets used to be free but now there may be a small charge.
Angus
rkillian
thank you,
i need these analysis results for thesis work.
I feel confidant that the world is so big, somebody will definitely help,
if you find please put it on this page.
(Ganesh)
Check with your advisor. I guess that the proper modelization of the structures you're working with is an important part of your thesis work. Give a chance to RAM Advanse, it's an easy to use structural program that has several load tools that I guess would help you.
to 2610 and others interested:
Stop trying to force-fit a solution! If you are in a technical school/working on a MS thesis, GTSTRUDL has an excellent offshore module AND Georgia Tech (producers of GT STRUDL) offers GTSTRUDL to other colleges and universities and at cost; which is worth 2610 looking into!
