About combo boxes
About combo boxes
About combo boxes
If I have 2 combo boxes (activex), how do I enable/disable the second combo box depending on what is chosen in the first one.
Thx in advanced for any help.
RE: About combo boxes
Put something like the following in the ComboBox1_Change event procedure:
    Select Case ComboBox1.Value
        Case 1
            ComboBox2.Enabled = True
        Case 2
        Case 3
            ComboBox2.Enabled = False
        Case 4
    End Select
Cheers,
Joerd
