Sketch- extrud cut-"endpoint wrongly shared" message-used to highligt
sw 2003 plus, When I make a sketch and try to extrude it I am getting an enpoint wronly shared error, which means either theres a break in the contour or there may be double lines.  I cant find where the problem in the sketch is, but I remember that I used to get a different color where the problem area is.  Is there a setting to make it do that?
RE: Sketch- extrud cut-"endpoint wrongly shared" message-used to highligt
Look under "System Options --> Colors".  This is where all the sketch state colors (i.e. underconstrained = blue) are controlled.
All this machinery making modern music can still be open hearted.
thank you for your honesty, yeah your honesty
Another way to locate the error is using 'check sketch for feature" under "tools" -> "sketch tools". make sure the entire sketch is in the viewable area before selecting the command. It will highlight the error but won't tell you if it's an endpoint error or a duplicate entity.
Eholmes
The "check sketch" option is a good one as eholmes suggested.  Additionally while using that option, you will need to specify the extrusion or cut that you are wanting to generate.  Another option, may not be the best or fastest, but, at times I will delete the line/lines in question and draw a new line from node to node.  This generally works as a result of removing the suspect entity.
Jay
