French drain induced drawdown.
Could someone direct me to reseach conducted into or information on evaluating drawdown and zone of infuence of a french drain.  I have volumes of fluid collected from the drain (i.e. pumping rates), and conductivity data and am trying to determine optimum spacing for standpipe piezos for monitoring.
RE: French drain induced drawdown.
Have you ever considered using analytical solution to obtain your answer or alternatively construct a simple two dimenional model to study the drawdown and zone of influence?
Seepage, Drainage & Flow Nets by Harry R. Cedergren.  An excellent reference.  Also look for COE dewatering manual - should be online by now.  It was written by Charles (Charlie) I. Mansur -
