Problem in Metal seated jacketed Butterfly valve
We  are having a Metal seated jacketed Butterfly valve  for vacuum service in our Plant fromthe year 2001. Now During Physical inspection of the Valve we are finding Metal
rubbing  in  the  Disc  &  Valve  Seat. The valve is also in
passing  condition. What could be the problem?
Thanks & Regards
Senthil
RE: Problem in Metal seated jacketed Butterfly valve
The problem can can have numerous root causes so to provide a solution you need to provide more data.
Location of Damage to the valve centreline
type of damage
Line media
etc
Are you using a High Performance or Triple Offset Valve. High Performance BFVs always rub near the shaft line.
