Filter and sum
Filter and sum
Filter and sum
I use a filter on a table to sort parts by reference. on the next column is the price of the parts. When I sort parts by ref I would like to have Excel calculate the sum of the displayed prices only and not the full column of prices.
I'm looking for a function to do so, but if it can only be done by a macro, it's fine as well.
Many thanks,
Cyril Guichard
Mechanical Engineer
RE: Filter and sum
nevermind, i found it
SUB.TOTAL(9,ref1,ref2,...)
Cyril Guichard
Mechanical Engineer
RE: Filter and sum
sumif may also work
Rick Kitson MBA P.Eng
Construction Project Management
From conception to completion
www.kitsonengineering.com
RE: Filter and sum
Will check it. Thanks for the tip.
Cyril Guichard
Mechanical Engineer
RE: Filter and sum
You might also want to consider using a pivot table for this
TTFN
