Entering New Dimensions on repeat jobs
Is there some way of changing dimensions on jobs easily on repeat orders? Our drawing office currently print off not-to-scale templates and add in the dimensions by hand. The result is alot of human error, an extensive manual filing system and duplication activities as a result.
The short term method of dimensioning by hand has left us with long term drawing office lead times.
The obvious answer is a database but the drawings take considerably longer to produce when entering the dimensions on screen. Also the shear amount of drawings that are filed will be difficult to enter into the database.
The software used is radan for sheetmetal.
Any comments welcome.
RE: Entering New Dimensions on repeat jobs
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
