welding copper to aluminum is it possible?
I would like to know if it is possible to weld copper and aluminum together using a laser. If so please share the secret. The laser being used is a 4000 watt direct diode laser. Also, would it be easier or possible to use a filler like brass, and weld the copper to brass then the brass to aluminum.
Thanks.
Thanks.
RE: welding copper to aluminum is it possible?
1) Silver solder a "butter layer" onto the Cu.
2) Weld, using Al filler, the Al to the Silver solder.
This may form the basis of a welding procedure for yourself.
Niekie Jooste
http://www.ilt.fhg.de/eng/jb00-s51.html
It mentions brittle, intermetallic phases developing in the joint zone, but they managed to overcome that.
One of the best ways to weld Al to Cu is friction welding -but that's probably no help.
