Full Bore vs Full Port
Can any one help me with the explanation of the difference betwen Full Bore and Full Port Valves
RE: Full Bore vs Full Port
No difference in the valve. Just a difference in terminology.
BCD
why do reduced bore valves tend to be cheaper than full bore valves of the same application?
is it true that full bore valves are preferred over reduced bore valves when the application tends to choke easily?
Thanks..
Check thread 408-20283 for a full explanation of full versus reduced bore ball valves. Full bore valves are used when the pipeline must be cleaned by pigging, or when pressure drop is absolutely critical. There cannot be many applications where sufficient flow exists to "choke" a full open reduced port ball valve. The flow velocity would exceed normal piping design guidelines.
bcd
They are smaller, lighter and the design is simpler. I think thats why. Volume may also influence.
Best regards
mORTEN
FYI Reduced bore valves can also be referred to as Standard bore/port.
My understanding is full bore refers to ball valves, full port refers to globe valves whose orifice size same as the PIPE ID.
Rgds,
209larry
Be careful to offer reduced bore in case of pigging requirements for the referring pipeline.
Hans
If pressure is the issue rather than flow, standard port is acceptable.
J. Alton Cox
President
DeLuca Test Equipment
www.delucatest.com
