component array problem in assembly
HI,
In my assembly I inserted an array of an existing component.
This particular component is now removed from the network.
When I open the assembly the warning is given that the part is not loaded, because it is no longer available. When I try to delete the parts in the assembly navigator it removes all occurences except for the 'master' component.
How can I get rid of this dirt in my assy?
Thanks, Martin
Thanks, Martin
RE: component array problem in assembly
you should be able to delete the master in the ANT at this point.
hope you followed this
just shout if it did not fix your problem.
best regards........ gary
The option of editing an array is only possible in the gateway mode, NOT in the modeling mode. This explains why I didn't find it myself in the first place.
This took me a while to find out. thanks!
Greets Martin.
