File>open menu gone
File>open menu gone
I seem to have lost the menu interface when opening files in MDT 6. I now have to type the full path and file name into the command line.
Does anyone know how to turn the windows menus back on?
RE: File>open menu gone
Not sure if this helps or not.
Sean
That did the trick. Thanks!
Lou
Sometimes you will also loose your command dialog boxes that pop up when doing an import or other various commands.
You will need to set the "CMDDIA" variable back to 1.
I have been loosing this when ever a printer locks up, or after the CTRL, ALT, DEL shut down. I have been dealing with it since ACAD v12 for windows.
As I also use Pro-E I hadn't been on MDT for some time. I installed V6 and lost the file-opening menu during a failed IGES import task. Setting FILEDIA and CMDDIA to '1' fixed it!
