de-Gaussing magnetized pipe prior to welding
Does anybody have a sure-fire way of de-Gaussing a piece of 9Cr-1Mo pipe in order to make a GTAW weld?  The section of pipe is magnetic and plays havoc with the arc from the Tig torch!
RE: de-Gaussing magnetized pipe prior to welding
Use a single or if more power is required yorks from a magnetic particle tester.,  Use AC put on and pull off. Several times may be required.
Rich
