D.C. Brush motor
D.C. Brush motor
D.C. Brush motor
I have been looking at a D.C. Brush motor that is rated at 60 volts, 12.9 amps con't, 58 amps peak. It also has a Ke of 13.4 v/krpm and a Kt of 1.13 lbin/amp...Does the Ke mean if I put 13.4 volts into the motor I will get 1000rpm out????
Can I use a unregulated supply??
Thanks for any help
RE: D.C. Brush motor
Yes, if you apply 13.4 volts, the motor will go ~1000 rpm. Ke is the Voltage constant, defined as you have it Volts per 1000 rpm...how many volts does it take to go 1000 rpm.
Yes, you want to use an unregulated supply. From what I have been told, a regulated supply can starve the motor of power when demanded.
Cameron Anderson - Sales & Applications Engineer
Aerotech, Inc. - www.aerotech.com
"Dedicated to the Science of Motion"
Suggestions marked ///\\\
///Yes, since Ke=V/RPM=13.4 V/kRPM, or
RPM=V/Ke=13.4V/(13.4V/krpm)=1000 rpm for 13.4 Volts.
k=1000\\\
///A regulated power supply will keep the voltage at about the same level with the motor being loaded on its shaft.\\\
Ke is called as back  emf constant. It indicates the relation between motor speed and induced back emf. Ke will help you determine motor armature current at certain speed such as
I=(Applied Vdc- Ke*speed)/R_armature.
This equation ignores field current.
If you ignore I*R_armature  then your understanding is right. But usually this is not the case.
If your application does not require precise speed regulation, than you won't need regulated supply. Because voltage variation will directly effect the speed.
