Fatigue Failure of Alloy 800
I have an agitated vessel that we inject live steam into for direct heating/mixing. The vessel is 8 y/o. The welds at the support lugs have developed leaks due to cracks. The shell is Incoloy 800 and the support lugs, which distribute the stresses, are SA-285 carbon steel. I'm looking to replace it with a new one.
Questions
1) Would PWHT the vessel prevent this???
2) Could/should I specfiy the lugs be Alloy 800???
3) The lugs are attached to the vessel with a SA-285 pad. I'm thinking if I change the Pad to Alloy 800, the dissimilar weld will be moved off the pressure retaining shell.
Thoughts???
Questions
Thoughts???
RE: Fatigue Failure of Alloy 800
dont try to PWHT unless you have a good reason, its not a straight forward process with this metal
check for local high stress, maybe the agitator is setting up reaction stresses and you are getting fatigue cracking
The APIGUY....
1) what weld filler metal are you using?
2) what kind of temperatures are you seeing? (are they cyclic?)
Also, I agree with Aybee and your approach of making it all similar material. But, it would be interesting to note the other environmental variables...
~NiM
The comments from the others are right on. And remember, without any of us knowing a lot more about your situation, none of us can make an accurate judgement. (Referring to Aybee's comments that the weld may be subject to fatigue cracking.)
There are a lot of other things to consider when doing the replacement, including asking yourself if Alloy 800 is the right material for the job. (As I'm sure you are aware.) When I'm specifying new equipment replacements (due to failures) I want to know EVERYTHING. This includes the total environment within and outside, any forensic metallurgical evidence of failure, potential failure points, potential damage mechanisms, upset conditions, etc.
Good luck!
~NiM
