Pro to Ansys problems
all:
Running Pro 2001 I have created and assembly, when the client pulls the
assembly into design space (ansys) he can not select surface to control
the meshing.
The parts had the same problem, I tightened the accuracy and the parts
worked fine. The problem is that the assembly will still not work
properly. Any suggestions on why this is happening and how to fix it?
Dan
the meshing.
Dan
RE: Pro to Ansys problems
