Press fit II
Press fit II
More specifically, I have a device that has a press fit handle. The pins and the holes for the press fitting are not exposed, kind of like a plastic squirt gun. Those are sometimes ress fitted and glued. Anyway, how could I disasemble the hanle of this device without damaging it. Also, there is a hole in the back of the handle that alows you to see the pins connected to the holes of the press fit. I'm wondering if I can use this opening and possibly get a tool that will use tension to separate the two mating pieces of the handle. Kinda like the squirt gun that has a hole at the back where you can fill it with water. Imagine trying to use that hole and insert something that can be used to disassemble the squirt gun with damaging the the gun.
Can anyone help????
Can anyone help????
RE: Press fit II
If you pressurize, be very careful that you don't overpressurize and make yourself a little bomb.
You might also be able to make a small mechanism with a lead screw and crank, something like a car jack.
Heating the side with the bosses would help to loosen the press fits.
Depending on the configuration, you might be out of luck, though.
RE: Press fit II
