Bolted Bonnet Design
Does anyone know the design code for the strength of bolted valve bonnet? It looks like a blind flange but with a centre stem hole.
RE: Bolted Bonnet Design
For a start, try going back to the Original Equipment Designer (OEM).  They must be able to supply you with data you require.
