Restoring ProE Wildfire syscol.scl at startup?
I'm fairly new to ProE Wildfire SE and I was wondering how to make the system colors I want used at startup? I have saved color schemes via the "syscol.scl" file, and I have saved it in many different locations hoping ProE would find it and load it at startup. I've gone through all the possible options in the "config.pro" file to see if there is a setting that will specify a path for this with no luck. I know it's there is a simple solution that any number of you could answer. I appreciate your help.
PCrosby
PCrosby
RE: Restoring ProE Wildfire syscol.scl at startup?
I think you should use
system_colors_file
config.pro option. The value must be the file name with the path.
I hope this helps.
Best reg's:
Jozsef Auer
mechanical engineer
engineer in informatics
CAD/CAM Application Engineer
Thank you Jozsef, that worked fine! I don't know how I missed that one when I was searching those setting variables.
Peter
