Cluster - Engineering Definition
I would like to know the definition of "CLUSTER "
which was most commonly used in Gear Industry and Dash Board Instruments Manufacturing Company.
RE: Cluster - Engineering Definition
Frequently the pinion is longer than the mating gear because it requires overlap on both sides, and it requires a longer face width to accommodate the higher stresses that pinions experience.
As you progress in the gear train, the pitch generally becomes coarser. There are higher loads and stresses because the cluster torque keeps going up stage by stage. Also, the face widths tend to increase with every stage for the same reason.
That's no longer practical so it all gets built into the IP, which in itself is tested prior to assembly into the car.
Cheers
Greg Locock
If we consider in the gear box , two or more gears ( either pinion or gear ) in the same integral shaft which engages in the other pair of Cluster gears .
If we consider the Instrument panel , Speedometer ,RPM Meter , Fuel Gauge , Temperature gauge and other indiactors are mounted in the Single Module it is also called Instrument Cluster.
or in mixed company, a Charlie Foxtrot. Quite an entertaining dance to watch, eh?
