What is "subsynchronous"?
I have a portabel vibration analyzer, CMVA60 (MAKER:SKF).
When I print the vibration spectrum, the output is consist of spectrum and displacement value of overall/ synchronous / subsynchronous / nonchronous.
what's the overall/ synchronous / subsynchronous / nonsynchronous?
Please help me!
Please help me!
RE: What is "subsynchronous"?
syncronous is at 1x, 2x, 3x etc times running speed
non-sync is not syncronous. I believe non-sync might also exclude sub-sync (?).
overall combines all of the components.
Examples of non-synchronous would be rolling element bearing fault frequencies, or oil whirl in a journal bearing.
I understood "sub hamonics" is x/2, x/3....x/9.
(x=running speed).
Isn't "sub syncronous" equal to "sub harmonics"?
There can be other subsyncrounous vib which is not a subharmonic. Example is oil whirl which occurs at some irrational fraction 0.46358... times running speed.
(The 5 decimal places wasn't intending to convey the precision of my number, only that it was irrational).
2.)synchronous is also called as the 1xrpm, 2xrpm....10xrpm; or hamonics values of 1xrpm.
3.)subsynchronous all peaks located before the 1xrpm.
4.)nonsynchronous or sub-harmonics are peaks that are non-integer of 1xrpm e.g. 1/3rpm;2/3xrpm....etc or simply peaks between synchronous(1xrpm and 2xrpm.....9xrpm and 10xrpm).
No, that is wrong.
The test for whether they are synchronous is - do they maintain a consistent phase relationship to the rotational frequency? If they do then they are synchronous.
I must confess electricpete's example is disturbing, if the oil whirl speed is at a constant but irrational ratio of the rotational speed then I can't decide if it is synchronous or not!
Cheers
Greg Locock
But I agree, whirl is non synchronous.
I suppose my doubt was raised by thinking about using a triggered sampling method in the time domain. All non synchronous data averages to zero, as does subsynchronous data, and non-integer harmonics. Therefore how can subsynchronous and non-integer harmonics truly be considered synchronous? The answer is, in my opinion, that there is no such thing as sub-synchronous, it just means you've taken the wrong signal to use as the fundamental. We should use 1/2 order as our speed base for 4 stroke engines, for example.
Cheers
Greg Locock
I wonder if "non-synchronous" value is including "sub-synchronous" or not.
http://forums.skfcm.com/postlist.php?Cat=&Board=reliability
