max difference between phase currents during uncoupled run
31.6A, 30A, 28.4A. Would you consider it abnormal?
No, we haven't checked the voltages.
(Moved same clamp-on probe to all phases several times to establish repeatbility)
RE: max difference between phase currents during uncoupled run
That's ~5½% deviation...doesn't seem drastic. I'd note it and check under load.
[By using the reverse logic of some recent discussion here, would that imply that terminal voltage is balanced to within 1%?]
Let us assume the voltage is balanced within 1/2% range. I think that is typically what we see at our power plant (absent a power system problem).
Excerpt from IEEE 141 §3.8.2 Measurement of phase-voltage unbalance
The simplest method of expressing the phase-voltage unbalance is to measure the voltages in each of the three phases: [Method listed in ANSI C84.1 and NEMA MG-1]
voltage unbalance = maximum deviation from average / percent unbalance
{Also in IEEE 141} The amount of voltage unbalance is better expressed in symmetrical components as the negative sequence component of the voltage:
voltage unbalance = negative-sequence voltage / positive-sequence voltage
{No mention is made of current-imbalance relationships.}
I believe that motors may tend to have higher unbalance when unloaded. I am really looking to see what are typical values during solo runs.
http://www.energyautomation.com/html/methods/electricalsystemwork.php
etc. for more info
But you knew that.
