looking for compatibility issues with acadlt 2000
I am running acadlt 2000 on windows 2000 platform. It does allot of freezing and i have to then reboot.  I was wondering if there was a patch for this or it is fixed with acadlt 2000i? Hope someone can help.....
RE: looking for compatibility issues with acadlt 2000
look for an acad dump file or an acad.err file see if you possibly got any errors also what are you doing when you get kicked out check to see what your autosave settings are and wheather or not you have a virus scanner running in your system tray (its the area next to your clock in the bottom right hand corner of your screen)try booting into windows safe mode or VGA mode and see if you can reproduce it make sure you have all available patches applied
