Xerox 8830 plot margin problems
We just received a Xerox 8830 and are experiecning difficulty with its plot margins. Most of the time we plot Arch D 36x24s in Landscape format. Our titleblock is on the right-hand side of the drawing. From the right side of the titleblock to the edge of the paper, it *should* be .25".
Our margins typically are:
Top: .65"
Bottom: .65"
Left: .75"
Right: .25"
In Plot Preview, everything looks fine. When the plot comes out, there is about 1" from the right side of the titleblock to the edge of the paper. I've tried changing the Justification setting on the Xerox 8830 to "Right", as well as changing the "Over Margin" and "Under Margin" settings. Increasing "Under Margin" shifts everything to the right, which is what I want, but cuts a few things on the left and the bottom - no matter what the margins are changed to.
The *only* way for it to plot as close to the edge of the paper as we want it to is by changing the left and right margins to 0" and setting X-axis plot offset to 1". Why is this? We never had to do this on our HP DesignJet 600s.
Increasing the left margin to say, 1", pushes everything to the right (as it should), and everything looks good in Plot Preview, but when it's actually plotted, there still exists a 1" gap between the right side of the titleblock and the edge of the paper.
Any help would be GREATLY appreciated
Top: .65"
Bottom: .65"
Left: .75"
Right: .25"
RE: Xerox 8830 plot margin problems
Also: File -> Page Setup -> Layout Settings -> Plot Ofset by X and Y should help to you.
I usually set my margins to zero.
Good Luck!!
