Operating Frequency of Transformers
Why is it that a transformer rated at 60Hz cannot be operated at 50Hz? Doesn't hysteresis increase with frequency? What is the relationship between frequency rating and the amount of iron required for the core?
Thank you in advance for your help
CBDave
RE: Operating Frequency of Transformers
If you operate at nominal voltage with reduced frequency, the transformer will be saturated and the increased iron losses will lead to overheating and eventual failure.
