Grade/type of Ni-hard for ash slurry line bends
Calling any gurus in the area of slurry piping or wear resistant materials!
I'm getting some Ni-hard bends cast for re-routing our ash slurry line, but need some advice on the grade of Ni-hard material to specify. Pipework is approx. 330 diameter, flow approx. 220L/s. The bends will be coupled to cement-lined ductile iron pipe (otherwise socketed) running in a concrete box-conduit.
We have some Ni-hard bends on our coal mill discharge pipework of spec ASTM A532 Grade 1 Type 1, but I assume that our pulverised coal is somewhat less abrasive than chunks of bottom ash and a higher grade would be required. The equivalent British Standard appears to be BS4244 (grades 2B, 2C 2E etc.). However, I also note that the harder the material, the more brittle it'll be.
Is there a grade that is typically used for ash slurry? or is there some means of determining the abrasiveness of the slurry to indicate the hardness required?
Any comments/suggestions would be greatly appreciated.
Cheers
Cheers
RE: Grade/type of Ni-hard for ash slurry line bends
A good reference for Ni-Hard is a publication from the Nickel Development Institute, publication 11 017 (1996). You can ask for it on their website www.nidi.org.
