Al/Cu Inertia weld strength
In a nutshell:
A member comprised of 3" dia. 6061-T6 Al and 2" dia. Cu (cold-drawn) that has been inertia welded together. The aluminum piece is welded to aluminum pipe (3" Sch. 40) of varying lengths depending on product size. The inertia welded part is assembled onto a hinge.
Problem:
What is the strength of the inertia weld? The end of the blade will rotate from a vertical position to horizontal-impacting a stop to end its rotation. Will the impact force cause a failure?
Any suggestions on how I can progress?
Thanks in advance!
Problem:
Thanks in advance!
RE: Al/Cu Inertia weld strength
I would be very tempted to do test to destruction to prove fitness for purpose
