Editing problem
Editing problem
I was working in my drawing (.slddrw) and all of a sudden I can't change or delete anything. There are a couple of notes that I need to delete. What have I done wrong.
David A. Johnson
Thunder Systems Inc.
Corona, CA
RE: Editing problem
2. Did you insert entities on the general drawing frame instead of into (associated to) a view, or the other way round?
3. Exit, DON'T FILE, Exit SW, reboot and try again.
Those are the 3 most obvious things that come to mind. Well, except for the obvious thing to do - call your VAR and make use of the support YOU ARE PAYING FOR every year.
Good luck.
RE: Editing problem
1. I don't think so. But when I'm in the body of the drawing and not touching any other view the format icon is visable.
2. I inserted a partial section view.
3. What to you mean by "DON'T FILE".
DAJ
David A. Johnson
Corona, CA
RE: Editing problem
Being able to use views in this manner is benefical, but you just have to watch yourself when adding notes to your drawings.
IHTH,
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
RE: Editing problem
Heard some rumor of a bug with partial sections on one SP where the boundaries don't work right - anyone out there confirm this?
RE: Editing problem
What does RMB mean. I'm not up with the lingo yet
JNR
You mean exit without saving?
David A. Johnson
Corona, CA
RE: Editing problem
Bradley
RE: Editing problem
David A. Johnson
Corona, CA
RE: Editing problem
File - Close - NO.
RE: Editing problem
David A. Johnson
Corona, CA
RE: Editing problem
Would you mind if I yanked on that cord a few times
You are just jealous because the voices only talk to me.
RE: Editing problem
Using the drawing manager tree, select views one at a time, RMB and lock view focus, and try selecting the offending entitities. Don't forget "lock sheet focus", as well (actually, try the sheet first).
