Any info on ICL7106 or MAX7106?
I have to re-engineer a board that uses an ICL7106 - and a MAX8211.  There are 2 diodes in series from pin 21 of the 7106 to pin 4 of the MAX8211.  What function do these diodes provide.  ANy help would be great!
dwminer
RE: Any info on ICL7106 or MAX7106?
Did you look at the datasheet / app notes?
Yes I have reviewed the datasheets and app notes and have not found anything that explains the hookup.
Without the diodes, the display is "supposed" to be a 0-200 range.  With the diodes in, a 0-100 range.
dwminer
Your posting makes no sense.  Pin 21 on the Maxim ICL7106 is the Backplane drive voltage for an LCD display and is nominally 5V.  Pin 4 on the Maximm MAX8211 is an output current sink.
Whoever did the reverse engineering appears to have made a mistake altogether or missed a connection to something else.
TTFN
