Yokogawa UT37 Temperature Controller Communication Interface.
Hi all, I need your help for information.
Currently I have a DOS base communication interface with Yokogawa UT37 temperature controller, using C++ programming language.
My question is, I had search for this kind of communication interface for Windows NT 4 base, but still cannot get it. Do I need any driver or library to install into Windows NT 4 for communication interface?? I found that DOS base communication interface are using RS485 COM Port, but i also found that the program had include moxa-cl.obj library file. It make me confuse to continue to modified from the DOS base program to Windows base program. Please advice me if you know any method of writing a source code for this temperature controller communication interface.
P/S: I am using Visual C++ 5.0 to write the program. Thanks.
RE: Yokogawa UT37 Temperature Controller Communication Interface.
1. It seems that you have a special I/O card with a RS485 port on your PC. Is it?
2. The DOS program seems to use a special object file, moxa-cl.obj, while linking. Do you have that file?
3. Windows NT does not permit direct hardware access. There is a way to fool the OS, though. Techniques used in the DOS program may not work in NT at all.
Feel free to contact me over email.
Cheers
Rahul
rahul_y0020@americanreadycash.com
