Divergent Flotran Solution
I am running a fairly simple 2D FLOTRAN analysis, and ANSYS keeps giving me an error when I run FLOTRAN saying that the "Coefficient Matrix has a negative diagonal." I've solved this same problem previously last week without any problems. But, since then I have not been able to get a solution. I actually haven't been able to solve any FLOTRAN problems because of this error for nearly a week. I was wondering if there was some minor thing I may be activating or deactivating that might cause this. Any help anyone could give me would be quite beneficial.
RE: Divergent Flotran Solution
Are you working well with your fluid DOF ?
Try with this
Main Menu>Solution>FLOTRAN Set Up>Relax/Stab/Cap>MIR Stabilization
and use in MIR Stabilization = 0.1 or 0.2 ( max 1.0)
and try the analysis again.
Also read "Relaxation factors" in Ansys help
This relaxation factor will help in conditioning the numerical operations avoiding "Coefficient Matrix has a negative diagonal."
Try with this
Mohr
Z
