How big a hydraulic press would I need?
I'm wanting to press bowl shapes into 3mm mild steel. The bowls will be about 300mm x 600mm and about 150mm deep (thats 12" x 24" x 6" deep for the imperial sorts).
How do I calculate the size of hydraulic press to use?
It's only a short run (less than 100) would explosive forming be better?
