Remove Group LISP
Remove Group LISP
Remove Group LISP
Does anyone know of a LISP that will delete all groups from a drawing. I don't want to delete the enities of the group - but just want to get rid of the grouping without having to manually delete each grouped object (hope that makes sense)
Thanks!
RE: Remove Group LISP
By groups do you mean blocks?
No - they aren't blocks exactly - they are a named selection set of objects - they act almost as blocks but they are able to be edited.
;Disband - a command to disband all Groups in a Drawing
;without destroying their member elements
;Please post debugging results
;written by Dr. Tigrek
;www.homescript.com
(defun C:Disband()
      (setq objdict (namedobjdict))
    (setq grpdict (dictsearch objdict "ACAD_GROUP"))
      (IF (setq SONNY (dxf 3 grpdict))
          (princ "\nGroups and Bands Found in County - and disbanded:")
        (princ "\nCounty clean of Groups and Bands")
    (princ "\n")
  (while (setq grpdict (member (assoc 3 grpdict) grpdict))
    (princ "\n")
    (princ  (setq GroupName (cdr (car grpdict))))
    (setq GroupEDNA (cdr (assoc 350 grpdict)))
    (entdel GroupEDNA)
    (setq grpdict (cdr grpdict))
(princ)
Thanks for the LISP. Can you tell me what this means?
Command:
Command: DISBAND
; error: no function definition: DXF
Command:
This was copied from the command line after I ran the program.
Please add the following function definition to the lsp file after the end of the function disband.
Thanks for the debug feedback.
(defun dxf (n ed) (cdr (assoc n ed)))
