bearing software
bearing software
Gents,
Does any body knows a site or free software i can use to calculate the radial/axial loads on the bearings? do you know any good bearing site for technical info.
upm
upm
RE: bearing software
Thanks alot for the replay. i am looking for this softawre to evalute the bearing load on our fin fan reduction gear box and verify the vendor calcas whcih uses FAG software. I am in belive that the existing bearings are undersized and need to be modefied for excessive shock loads and need to re-confirm the radial.axial loads.Our bering rep. are sales only and not that helpfull.
thanks for the advice
upm
kingsbury,inc
waukesha bearing
bently bearing
SKF
Lester Milton
Telford, Shropshire, UK
would have software
available or could
recommend some good sources.
Franklin Institute designed
and tested for NASA and also
may be a good source.
It will probably cost nearly
3000 us dollars and need
someone to walk you thru the
many options.
I would submit your input data
to several bearing manufacturers
for calculations. some may be
reluctant unless you are talking
about 50 bearings or more. Most
companies do this for free and
will often give you the calculation
data in detailed form if you
require it.
