AutoCAD drawing keynote - legend reference add-on
Does anyone know of a product that will run within/work with AutoCAD 2002 and higher for a drawing noting system? AutoCAD r14 included a tool to do this, but we cannot find it in the newer versions. An add-on was recently purchased that was thought to work, but does it not provide the same functionality.
What is needed is a routine or external program that can run within a drawing with keynotes and reference an external database and insert the text that goes along with the keynote into a column on our drawing.
For example, a detail will be drawn and point to an object with a note that says "07460.F". There then needs to be a legend on the side of the sheet that says "07460.F VINYL TRIM". The progam needs to be able to scan the text on the sheet and generate the legend on the side of the sheet. The drawings are architectural in nature.
Any help is appreciated!
Joe
Joe
RE: AutoCAD drawing keynote - legend reference add-on
I should have mentioned the previous ability to keynote was part of Architectural Desktop v3.2, not ACAD r14. I appologize for not making that clear in my first post.
Architectural Desktop v3.3 seems to be missing this feature. Some solutions have been found, but have more features than are actually needed.
Joe
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
That sounds like the concept exactly. Insert keywords, and then have those keywords indexed and a legend created. Know of any generic scripts that can be modified to do this?
I do not know of any offhand. I have done some VB routines similar to what you are doing. Do you know VB?
.. Henry Ford
