high motor load
high motor load
high motor load
gents,
i am going through a buzzle here. two identical 3 kw pumps, motor for one of them is pulling 95% FLC and cannot even throttle the discharrge block valve? we inspected motor, pump bearing, impeller and even seal. do not know what else can i do?motor no load test is 30% of FLC and vibration levels are ok. i am only questioning the volute geomatry for that pump which will effect the hydrolics? if they are pumping water and no change in the process.
pls. advice
RE: high motor load
Tricky,
have you checked the rpm?  Perhaps a simplistic approach, but since the rule of thumb is that a decrease or increase in pump speed change the motor load to the power of three.  Pehaps it could be a start.
RE: high motor load
What's the motor load on the second pump, and what's your anticipated load at normal operation?  Also what did you check for on the impeller & bearings?  My first guess, assuming it's just one of the two pumps that's showing significant load, would be wear ring clearance (not sure if that's applicable on your impeller, it's a pretty small pump) or a coupling misalignment - might cause some radial forces on your bearings that's causing extra motor load.  Depending on the bearings, the extra load could still be well within what they can handle, so not be apparent as damage.  Just a guess at this stage in the game though.
RE: high motor load
You sure one pump is not turning backwards? Check the elect connection for correct rotation.
RE: high motor load
Sorry but I just don't understand what you are telling us.
"motor for one of them is pulling 95% FLC and cannot even throttle the discharrge block valve?"
What does it mean?  Why can't you throttle the discharge valve? What is the position of the valve? What is the flow and dp? How does it compare to the pump curve?   What is the current, flow, dp of the other pump?  What is it that you consider abnormal?
RE: high motor load
Gents,
Thank you all for your reply and sorry i may not explained the problem well.
electricpete:
I ment the motor is alreday pulling 95 % load while pumping against blocked disharge valve. Therfore, once we line up the pump (throttle the discharge block valve) the pump will operats on the curve to develop the diff. head and flow which will requires more power. therfore, the motor load will increase as a result so there is no more room  to develope the head/flow.
I checked the rotation and it is as per the design even as the other pump.
the motor load on the good pump is 74 % at the operated point, and at SOH it is 60 %
We did inspect the pump internals and no bearing damage/excessive clearances or any clear mechanical damage.The motor is also inspected and no problems, even we cheked the impeller dimentions against the good pump impeller.
The RPM is correct.
Gents, it is a buzzle and am trying to work it out and need your help as if one of these pumps failed and theother tripped on overload, the plant will be down
RE: high motor load
upm,
From the information that you have provided, we can not determine if the problem is the pump or the motor.  If you remove the high amp motor (from pump 1) and couple it to the other pump (pump 2), if it continues to draw high amps at shut-off, you will know the motor (from pump 1) is not correct.   And the corollary, if the high amp motor operates properly on the second pump - the problem is pump number 1.
I would secondly suggest that you contact the pump supplier for their comments and recommendations.  We assume that these are new pumps.  Warranty should cover such problems.
RE: high motor load
Kawartha,
Thanks for the advice, however i thout of your suggestion but there is no way to stop both pumps as the level in the drum increases and might reach the trip setting for the main compressor.
Pump/motor vendors are puzzled as well and have nothing to add. i am trying to prove that the new pump hydrolics is some hoe has different behaviours that the other and then i will force the vendor to buy a bigger motor as the train is strail under warnty
upm
RE: high motor load
upm:
Looking at all the post you have considered about all there is.  I liked Kawartha's idea about changing motors.  I would like to add the following:
1)  Did you no-load test the motor on a shop bench or on the pump/motor frame?  Using the actual power/control system may tell you there is a starter/power problem with this one unit.
2)  Assuming you have checked both the pump and motor could there be an alignment problem?  This could include a mounting frame problem that will twist or piping problem that will allow mis-alignment only during operation.
3)  Considering how critical these pumps are for your operation can you justify an extra motor or pump for inventory?  Do you have a motor rebuild shop that you could borrow or rent a motor from?
Good Luck
RE: high motor load
well,
I did not check the pipe strains yet , however there is no missalignment frequency appear in teh spectrum. we have no solo run data at the work shop.
any way today we will install the motr monitoring software to watch the electric parameters and see how it goes.
Do you think the seal tension can impact the load? it will but how to justefy changing the seal?
upm
RE: high motor load
A few scattered ideas:
#1 - If it is a pure axial flow pump (often used in hi-flow, low dp applications), then maximum shaft horsepower is delivered to the pump in the valve-closed position. Then what you have reported may be normal... opening the valve would decrease motor current.  Do you perhaps have a reading of current with the other pump in similar configuration?
#2 - It could be a severe air-gap problem on the motor which allows it to draw excessive magnetizing current.  Measuring the power factor angle of the input power will help you determine whether the current drawn by the motor is reactive (magnetizing) or real (associated with some real power dissipation).
While you are at it you might as well measure the three phase currents (compare for balance).
#3 - You absolutely must measure the shaft-speed with a hand-held tach.  It is a very easy thing to do.  Then confirm that speed against speed assumed in pump curve.  Also use it as a way to evalute motor.
#4 - Any abnormal vibrations seen? What frequencies?
RE: high motor load
Since it is a 3kw pump, is it perhaps a single-phase motor?  If it is a capacitor-start motor, there may be a centrifugal switch which is supposed to cut out that cap once it comes up to speed. Failure of that switch to open might cause high current.
Also might be worthwhile to check your connections and voltages.
RE: high motor load
electricpete,
it is a centrifugal pump 3 phase motor. we did measure the speed by hand hels tack and was normal, diecrtion of rotation was correct . we did measure the current usng a clamp on ameter at each faces, check the motor manager settings as well.
\how to measure the power factor angle?
RE: high motor load
upm:
About the seal:  Yes the seal can cause your problem.
About electricpete:  Pete is "very smart" about power systems and pumps.  Very smart!  For what it's worth in this case I will make a few assumptions.  If all three pumps are in the same location I would expect they are feed from the same power supply.  Being on the same power supply if one has a problem due to phase angle or power factor then all three of them would have the same problem.  You can use an oscilloscope to check them, but I doubt this will solve your problem.  In most cases if you suspect a seal you should contact the seal manufacture.  We use John Crain seal on out pumps and they are more than willing to come to a location and validate seal alignment/operation for us.  Your manufacture will most likely do the same for you.
(Pete please take it easy on me, I'm still trying to learn)
D23
RE: high motor load
For a cetrifugal pump, the load should be minimum when the discharge valve is closed. But, in your case it is not. My first impression would be that there is something wrong with the motor itself, and not a mechanical fault. specially if the pump was not showing any upnormal noise, vibrations of heat.
You might try to replace this motor with a spare one and see the results. this will confirm to you if the problem is mechanical(pump), or electrical(motor).
RE: high motor load
d23 - thanks for the kind words... not entirely deserved.  There are plenty of knowledgeable people here including yourself.
upm - In the terminology of the Karassik's pump handbook, an axial flow pump is a "centrifugal" pump. Axial flow pumps draw max power under valve-closed conditions.
The only axial flow pumps I have seen are large power plant circ pumps.  I don't know if there are 3kw applications for axial flow pumps, but I think it is worthwhile to verify that either:
1 - this is not an axial flow pump
or
2 - other pump/motor in similar condition drew less current.
RE: high motor load
upm,
seing as how you can't shut down both units at once, I'd get the manufacturer to come out with a 3rd unit and replace each in turn.
Start with the suspect pump, change it out with the new pump.  Measure the performance of the "new" pump and if it is OK, tell the manufacturer to take his pump away and fix it... problem solved.
If the "new" pump displays the same problems, replace the second pump with the pump you removed from the system.
If the pump then behaves as per catalogue, you have a system problem, not a pump problem, either way you have made progress.
If it is a syatem problem I'd look at the following
1.  Voltage drop on the "problem" pump under load
2.  Discharge pressure on the problem pump
Just some thoughts.
dadfap
RE: high motor load
Check to see if the impeller rotation direction matches the volute rotation direction ( the volute cutwater and impeller tips should be pointing in the same direction).  The manufacturer could have installed the incorrect rotation impeller.
RE: high motor load
upm:
The impeller design can be part of this.  Is your pump a radial, mixed, axial etc design?
What happens with your "good" pump when you close the valve on it?
A low specific speed pump where you have high head, low flow and low pump eff. could have a very flat BHP curve.  It is possible for a pump to require more HP at shut-in that at open flow.  (dadfap check out one of my DN-4000 pumps.)  The probability of this increases with smaller OD impellers.
You can look at this web site for more info on specific speed:
http://www.mcnallyinstitute.com/CDweb/s-html/s072.htm
D23
RE: high motor load
Gents,
Thanka lot for all your advices and support, sorry for not replying but i was busy with this pump amd some other as well. To answer some of your concerns, these are radial flow pumps and not axial, the impeller is open. The good pump is drawing 60 %FLC at SOH
CB2
what do you mean by "Check to see if the impeller rotation direction matches the volute rotation direction ( the volute cutwater and impeller tips should be pointing in the same direction" we measured the cutwater angle but did npot know how to check the direction of volut? pls. help.
new info:
1.wehen i ternded the motor load i noticed the cyclic waves at constand process demand?? thus the motor load is varying from 88 to 100% FLC at constant discharge control valve opening? who can we explain it? we measure the mps by clamps on ameter and was matching the motor manager? what is this???? have no idea
2. There is a R.O installed on the GOOD pump discharge nozzle to control the curve shape  and not in the new pump? does it make any difference since i am throttling the discharge valve?
pls. help
upm
RE: high motor load
Just to recap:
30% FLC with this motor running solo. (that was in your 1st post... later you said not checked?).
95% FLC with this pump at SOH.
60% FLC with other pump at SOH.
Curernt balanced all three phases.
Voltage checked good (?). Bearings good. No indication of misalignment.
Forget my comment about checking power factor. Air gap problemw ould affect solo current.
Lots of good comments by others above.
One possibility - Oscillating current is one symptom of a rotor bar problem.  Check to see if the frequency of oscillation is pole-pass frequency (slip speed times number of poles). Also look for pole-pass frequency sidebands around 1x in vib spectrum (may require high resolution).  Just a possibility.
RE: high motor load
d23,
you gotta admit, that's onle lousy pump curve!  The GC4100 is much better :)
(For those of you who are not aware, d23 & I work for competing companies)
All the best
RE: high motor load
ump,
If your pump is "centerline discharge" type you can ignor my post.
If the discharge nozzel is to either side of centerline, the pump is probably available in a CW or CCW assembly.  The point is you cannot mix the impellers and volutes, they are dedicated to a specific rotation direction.  If you had a CW impeller in a CCW volute it would be similar or worse than running a pump in the wrong direction.
OK?
RE: high motor load
cb2
thanks for the comment
upm
RE: high motor load
The fluctuating motor current at fixed valve location is likely pointing to fluid problems: viscosity changes, cavitation, etc.
I have seen motors pull near FLC pumping into a dead head condition. I would be looking at a fluid problem. assuming all are powered from the same circuit (same electrical parameters).
RE: high motor load
Buzzp,
What other checks do you suggest? system NPSH is adequate and the other pump is running fine from mechanical/performance point of view.
I think i have checked for everthing and am looking at others to go.
appreciate your advice
upm
RE: high motor load
Some ways to check for rotor bar problem:
Measure running speed with a handheld strobotach.
Slip speed = Syncrounous speed - running speed
Pole pass frequency = #poles x slip speed.
If the current is peaking at twice pole pass frequency, the problem is likely broken rotor bars.
Also if you have spectrum analysis capabilities, look for pole pass frequency sidebands around running speed in vibration spectrum and around line frequency in current spectrum.
RE: high motor load
Ed(mechanical)
Gents,
We have deep well pump(3 stages) model grundfos @ 110 gpm, 2dia discharge line, 65M tdh & 11.4 amp. FLC. Triffing once a day, the contrl panel indication are overload current & dry run.
What is the probable cause of the stated pump. Pls advise.
RE: high motor load
Ed - I think it would be pretty confusing to discuss symtpoms from two different problems in the same thread. Can you start another thread?
RE: high motor load
I think electricpete has some good advise on rotor bar problems. I have no experience with this but sounds reasonable.
Are both pumps getting fluid from the same source?
Does the motor trip on OL if allowed to pump anyway? What is the current when the valve is fully open, is it normal? Maybe I missed this info from a previous post.
RE: high motor load
This happened to me during operational testing on a 500hp Baldor motor long coupled to an end suction pump. Except for one thing, during testing at full load the motor RPM decreased dramatically. 75%! The motor was no load tested prior to installation with satisfactory results but would not operate under full load conditions. During inspection of the motor a full core test was conducted and found that core insullation was the cause for the motor malfunction.
   Have your motor checked under full load at a reputable repair center and ensure the core is checked also.
RE: high motor load
Poppeye,
is there a procedure for such testing? i am not aware of this type of teseting, what facility (shop) is it required for such testing. FYI at our industry, there is no motor manufacturer?
upm
RE: high motor load
UPM,
    In Cleveland there are two motor repair facilites that can test the core, Monarch, and Redmond Waltz. They can also perform a complete core test for insulation breakdown and perform bench full load testing. Ingersoll Rand recommends that motor repairs on motors over 50hp, full core tests and load testing be performed prior to reinstalation.
RE: high motor load
Gents,
to update you on the status of this problem. after a hard work trying to convence electrical group to send the motor to a specialized work shop, the problem was solved. during the motor inspection, it was found that the rotor was bowed and unbalanced (was not shown in the vibration spec) and grease was found on the windings. bearings were overgreased . after repair, the motor load is about 76 to 90 % running smooth , load at SOH is normal and the unit behaves much  better.
it is a leason learned that we need to do detailed inspection even for such a smaller motor.however, this smal motor was about to trip the plant as it it pumping from a compressor knock out drum
upm
RE: high motor load
upm:
Thanks for taking the time to reply!
D23
RE: high motor load
Yes, always great to have the feedback.
Now we have to ask what did we learn.  Have you drawn any conclusions on the exact cause?
There were two problems... excessive grease and bowed rotor.  Which one caused the symptoms?
Which would cause excessive current and oscillating current?  I would say the oscillating current could come from the bowed rotor due to pole pass frequency oscillations associated with varying air gap.  Hard to think how excessive friction from grease would cause oscillation.
An interesting thing was that the current at no-load was 30% and apparently not oscillating (?).  I think most of us assumed 30% was normal, but do you have any info on actual no-load current?  One would think that regardless of the cause (either excessive friction from grease or varying magnetizing current from rotating airgap assymetry), it would show up at no-load.
RE: high motor load
electricpete
our electrical group is on top of this invistigation.as you said and as i was expecteing earlier, something will be related to the air gap and pole pass freq. we will include measuring this feq. as long as the rotor bars freq. to catch such a failure (if possible).overgrease can kill somtimes specially with high viscus grease (higher temp. )and maint. practice is to re-grease whenever there is a problem
upm
