Physical Properties of API grade Oils
Can anyone help me find of the physical properties (critical pressure, vapour pressure and cp/cv ratios) of differnt type of API grade oils?
RE: Physical Properties of API grade Oils
tell me which grades you need... i may be able to help you on this.
as there's a holiday on coming monday, earliest possible response would be tuesday, though, so if anybody else can help...
Primary interest is API 38 ?
ok, i'll try to get the numbers =)
give me time till tomorrow.
