Non-magnetic all-metal spring-energized vacuum C-seal
I'm looking for a spring-energized seal, similar to the one referenced below, but with a non-magnetic spring (this one is Nickel based)
http://www.helicoflex.com/catalogs/uhpuhv.pdf
A Beryllium Copper or Phosphor Bronze spring will do the trick.
The seal should be designed for 10-7 Torr
Thanks.
RE: Non-magnetic all-metal spring-energized vacuum C-seal
There is a company which can offer seals with springs in Elgiloy and I think it is non-magnetic.
http://www.htms.be
Hoping to have helped you.
