Concrete and rebar cage a good ground?
I haven't delved into the issue much, but now we have an issue here as to whether the rebar cage inside of a concrete column sunk 30 ft into the ground is a good ground. If the conrete is wet, I can see how it would be, but if for some reason the dirt dries out, my suspicions are that the dry concrete would not provide a path from the rebar cage to earth. Anyone checked into this issue?
RE: Concrete and rebar cage a good ground?
Search on "Ufer ground."
Look in the Green book from IEEE. Depth of the ground is nor nearly as important as the width (how spread out) the ground is.
