sulfur degassing
sulfur degassing
Need a brief explanation of the sulfur degassing process
RE: sulfur degassing
there is a good book written by previous Wsetern research (now Global sulphur) that was the best one when I used to work on Claus/TGTU units, you find a link to them through
www.sulphurexperts.com/SulphurExperts/ MainSx/SxMainPage.htm .
Try out http://www.goarallison.com/DGAASS.htm for Shell process and http://www.enersul.com/html/products/h2s.html for a catalytic version.
RH
I recommend that you either contact SulphurExperts (www.sulphurexperts.com) or AMETEK Process Instruments (www.westernresearch.com or www.ametekpi.com).
You may also want to consider monitoring the liquid sulfur's head space for SO2 and H2S concentrations. They are a useful indication of hazardous conditions within the liquid storage or degassing tank. For example, an elevated SO2 concentration in the vapor space above liquid sulfur can indicate the presence of a smoldering sulfur fire.
They have extensive experience in this field and they are an industry leader in the design of Sulfur Recovery Units.
Typically we use a mechanical agitation and sweep process or a licensed catalyst process, which our process engineers will be glad to explain to you.
