Friction Welding
Friction Welding
Friction Welding
Where can I find information regarding the strength of a friction welded joint between aluminum (6061-T6) and copper (cold-drawn)?
Thanks!
RE: Friction Welding
Try The Welding Institute : www.twi.co.uk
...and good luck
You might also try http://www.mtiwelding.com/ - they might give you a rough idea. But friction welds all have to be developed, metallurgically checked, bend tested etc on an individual basis. As a rough guide, it will be almost as strong as the aliminum.
