Involute Spline
Involute Spline
Involute Spline
I was wondering if anyone could tell me the equation to calculate the circular tooth thickness of an involute spline. The Machinery's Handbook has everything but that.
RE: Involute Spline
trallee,
try looking at ANSI standard B92.1b-1996.  Well at least that was the addendum we had here.  There are equations for max. effective tooth thickness, and minimum actual tooth thickness.  Let me know if you do not have access to this standard.
RE: Involute Spline
smitty1322,
I do not have this standard but will probably get it ordered. Do you have the equation available? I would really appreciate it if you could give it to me since acquiring the standard will take me some time.
Troy
RE: Involute Spline
Trallee,
Minimum actual tooth thickness is the value of the max effective tooth thickness minus the manufacturing variations fo lead, profile, adn spacing (gamma) minus the machining tolerances. Tmin=Tvmax-(gamma+m).
Maximum effective tooth thickness (Tvmax)has three different formulas all for different spline angles.
30 deg=(pi/2P)-es
37.5 deg= ((.5pi+.1)/P)-es
45 deg= ((.5pi+.2)/P)-es
I hope this helps.
RE: Involute Spline
Thanks for the info, this is what I was looking for.
RE: Involute Spline
Hi Trallee, did you got the standard?
Did it reach your need?
I know how to draw a involuted spline , but I do not know how far or near to Standar.
Feel free to ask more.
