Copper Backup Bars
Copper Backup Bars
Is there problems with utilizing copper backing bars when welding CP moment connections? I have a project where this is being proposed, the WPS and supporting PQR gave good results. However, somewhere I have heard or read that the SAC advisory and interium code changes discourages this ... maybe due to the possibility of cracking? I have not found any such reference in any of our documents. A review of AWS D1.1 shows that, at least from the perspective of AWS, that the use of copper is allowed.
Is there anyway, outside of a chemical analysis, to tell-tale if there is any mixing of elements in the weld pool by using copper backups?
RE: Copper Backup Bars
Copper pick-up is minimal, and most carbon and low alloy steels can easily tolerate a few more tenths of a percent anyway. When I was welding pipes, the copper backing bar would last for scores of welds. Just avoid having a GMAW arc directly on the copper.
Good luck
Gord
Copper pick-up is minimal, and most carbon and low alloy steels can easily tolerate a few more tenths of a percent anyway. When I was welding pipes, the copper backing bar would last for scores of welds. Just try to avoid pointing a GMAW arc directly at the copper.
Good luck
Gord
using TIG
