welding magnesium against C-steel
Can I weld C-steel to magnesium using any fusion-welding?
Using solid state processes, which one shall I chose?
RE: welding magnesium against C-steel
The current status of the project is finding applications that would be useful to industry. If you need answers to your question, let me know what alloy and size of magnesium along with what size and type of carbon steel. If there is a specific joint configuration that you must use, let me know that as well. I will try to incorporate this into my specific research and let you know what your options are.
Wayne
I madeno contact with this person since then. I thing it will be interesting for you and your project to contact Alberto González in albreg@cidaut.es.
Andrade
Wayne
