Composite Beam Studs
Is there a standard for the minimum cover over a compsite beam stud?  Any suggestions would be appreciated.  Thanks.
RE: Composite Beam Studs
Hi jakeh76,
In bridge decks, typically one wants the underside of the stud head to the top of the bottom transverse rebar to be greater than one inch.
VOD
