"Cryo" Tempered Razor Blades for Longer Life??
I was web-shopping for cheap Gillette Mach3 razor blades, and ran across the site http://greatrazors.zoovy.com/category/xx/ that advertises long lasting razor blades that are simply Gillette blades that have been cooled to -300°F for 24 hours (in the original box, no less! Read the site FAQ.)
Question is: Does this make any possible sense metallurgically? TNX
RE: "Cryo" Tempered Razor Blades for Longer Life??
dear friend,
it does make sense. in high carbon steels with or without alloying elements like chromium, the quenching for hardening leaves some residual auatenite in the structure. in hss tool-steel hardening and tempering it is common practice to deep freeze, a treatment similar to what you are refering, and then retemper it to reqired hardness level. the deep freezing treatment converts the residual austenite to martensite which on the second tempering will result in material which is hard and would remain un distorted. however, for very thin material like razor blade material, it is a matter of argument whether this treatment would give any additional benefit, except as an advertisement gimmick to attract people like you and me to interact.
regards,
MRCN
Jesus is THE life,
Leonard
BRT549 - I did find the Thread338-53716 "Keep razor blades sharp" once I opened up my search to all forums. It was pretty interesting. Thanks.
Some of these claims could very well be true but I remain skeptical of all of these claims except the tried and true and explainable/measurable transformation of retained austenite to martensite by suppressing the temperature below the Mf. The rate of temperature change is somewhat irrelevant for this since the phase change is not time dependant.
This comment about cryo is partly the cause for my skeptsism: "The exact metallurgy of this process is not known." But of course this does not invalidate it only calls into question the veracity.
Sometimes perception is worth more than truth so if it works for you go for it but you won't find me spending money towards cryotreatments until I see something substantive. I also might be forced to agree someday that UFO's are what they are puported to be.
Jesus is THE life,
Leonard
History: Swiss watches makers took thier die steels high in the Alps and aged them for several years prior to finish machining. Henry Ford aged his Motor blocks outdoors for several winters prior to finish machining.
As for edges I've treated an awful lot of knife blades and received good reports from nearly all. I've seen gains of up to four points in HRC,two points would be the norm. Wood carvers worried me to death. Prior thermal history will modify the results.
I buy a pack of elcheapo gillette disposable razors, and each razor lasts about 2 -3 months of daily shaving.
1 pack of 12 razors lasts about 3 years.
Not bad value for a couple of bucks.
On the possibility of other effects, I worked for many years in the ion implantation field. In ion implantation, atoms (actually, ions) bombard a surface with enough energy to penetrate a tenth of a micron or so, forming a new compound or alloy on the surface. The process results in a large increase in wear resistance -- two to three-fold. For many years, this increase was attributed to the surface alloying. The problem here is that the surface layer is very thin, so thin that it is removed in the first millisecond or so in a normal metal cutting application. Moreover, implantation with inert gases also produces improvements in wear resistance. Nonetheless, this remained the explanation given even in scientific meetings for over twenty years, until Russian researchers looked closely at the situation. They were able to discern changes in the microstruture caused by the bombardment down to hundreds of microns, with a region ten to twenty microns thick having high concentration of helical dislocations. The effects were very similar to those observed in a metal that has been deformed. Further, the improved wear resistance was found to depend on the depth of the helical dislocation structure, and independent of the thickness of the alloyed layer.
We looked at this issue from the stress point of view, found significant stress and strain changes induced by the ion bombardment. The strains were for the most part increased, but stresses varied depending on ion species. We found correlation between the strain increase and wear increase. In metals, we could not find a correlation between stress and wear resistance.
While these studies were carried out a decade ago, widely presented at technical meetings, with numerous articles in refereed journals, there are still practitioners that claim that the increased wear resistance is related to the alloying affect. So do not be surprised if those selling cryogenic processing don't have the foggiest idea of how it works.
Jim Treglio
Molecular Metallurgy, Inc.
Cryogenic processing works. The research shows it. The more industry uses it, the more we will learn about it. To those who will not use it because they don't understand it, I point to the Wright Brothers. They did not understand why their airplane flew, as their brilliant work was empirical. They made observations that under repeatable circumstances, they consistently got the same results. It took another 25 years to figure out why the plane flew, and even may current explanations are not correct.
The point is that cryogenic processing will give consistent results. It could save industry a fortune.
(all our steel tooling is cryo-treated as part of the heat-treating, likely retained austenite, but does also provide some dimensional stability, I'm still amazed that air-hardening steels will retain austenite thou.)
nick
The IIT study was on gear materials and done for the US Army Aviation and Missile Command by the IIT Research Institute. I have the Briefing from June 13,2000 by A. Alan Swiglo. Also, there was a recent Master's Thesis by Rajenda M. Kelkar, A Study on Effect of Cryogenic Treatment on M2 Tool Steel for the Thermal Processing Technology Center under Dr. Phillip Nash.
The Los Alamos study was done by Yuntian Theodore Zhu and presented at the Thermal Processing Technology Center at IIT on June 4, 2001.
I hope that helps. You can also contact me if you like. I forget if this forum allows email addresses, so I will not give mine, but if you do a search under cryogenic processing, you will find Controlled Thermal Processing, and you can email me there.
NickE:
A repeatable but unexplainable phenomonon is not snake oil, it is just not understood. To label it snake oil is to call reputable researchers liars and con men. Calling us (yes, I research cryogenics) liars is not a good way to discuss or advance science. If you have research that will refute our research, by all means bring it forth and let's discuss it like gentlemen. If you think our methods were somehow bad, show us the error of our ways. Otherwise science will regress into silly insult games. By the way, your mother wears combat boots!
Cryogenic processing is process that gives reliable and repeatable results. It has nothing to do with snake oil. If you deal with a reputable company that has the proper metallurgical staff, you have nothing to worry about. If you deal with someone who bought a cryo machine to become rich, and does not have the foggiest of metallurgical ideas, you will get what you paid for. The same could be said about heat treaters, welders, etc.
"(all our steel tooling is cryo-treated as part of the heat-treating, likely retained austenite, but does also provide some dimensional stability, I'm still amazed that air-hardening steels will retain austenite thou.)"
Air-hardening steels are slow to transform to martensite, so *they* are the ones most likely to have RA. Anyway, if you have time and want to look up an interesting paper, I recall reading one a few years ago that talked about the *benefits* of having some RA for some cases. Can't remember any details now, but the cry-o-boys probably won't like it!
This is of no concern to cryogenic processors because all evidence shows that there is more than transformation of retained austenite going on. For instance, military spec heat treat on 9310 specifies a cold treatment. This cold treament will reduce the retained austenite to a minimum. Subsequent cryogenic treatment of the cold treated material gave essentially the same retained austenite levels with a substancial increase in the wear resistance. This data is taken form the US Army Aviation and Missile Command study.
If you just cold treat to -150F, you will transform virtually all of the RA that is going to transform. Both research and practical tests show that superior performance is obtained by going down to -300F. It is fair to say that the transformation of retained austenite is not responsible for this increase in performance.
You must admit that the theroy of reduciton of micro cracks in grey irons (A type, class 35-45, mid size distribution) is not really applicable as the graphite flake acts the critical flaw. (I have seen some brake-rotor treating places state this.)
I used the term snake oil to describe a thing that works through an unknown mechanism. I agree that cryo-treatment works, ask my guitar player, the die shop we use, a buddy that races SCCA-club. My difficulty is that I've not seen a good metallurgical description of why. Retained austenite aside (and I'll have to read the references you give above), is there any known 1st principals or [s/p/p] reason for cryo-treatment to have the "incredible" effects that are generally credited?
nick
I appreciate your apology, and perhaps I came down a bit hard. It is very frustrating to those of us who are serious about this process to be lumped in with the "get rich quick" people. People who make wild, un-informed claims about "making metal denser", or "enhancing the molecular(!) structure of metals", or whatever have perhaps done irreparable harm to the field of cryogenic processing. Some companies are so paranoid about being scammed that they just will not use anything that has even the hint of taint to it. It is frustrating, because I see companies going broke because they are not competitive, and I have at least an answer to help them, AND THE ONLY WAY TO GET MORE RESEARCH DONE IS TO GET THE PROCESS MORE WIDELY USED SO IT ATTRACTS MORE RESEARCH.
I am not familiar with the theory of micro crack closure. Could you give me reference to go to on this? I would like to read it and also add it to my data base of cryo research.
Putting RA aside, especially since it does not explain why cryo works on copper, aluminum, some plastics, etc. cryogenic processing has been shown by NASA to reduce residual stresses in aluminum welds (Effects of Cryogenic Treatment on the Residual Stress and Mechanical Properies of an Aerospace Aluminum Alloy, Po Chen, Tina Malone, et al, Marshall Space Flight Center). There have been similar findings on steel, but I do not have their reference at hand. This in itself is interesting, though, because we treat a lot of valve springs that have been shot peened to induce compressive residual stresses to enhance fatigue life. We get about triple the life, so if I am reducing the compressive residual stresses, why does it last longer?
But I digress. Collins found the creation of very fine carbide particles. This may have some pinning affect to the crystal structure, but it is not valid for non-ferrous materials, of ferrous materials that lack carbide forming elements.
A common thread that is emerging from the studies that I have read is that something must be happening in the sub-micro structure. Any real theory would have to abandon the RA and eta carbide angle to work on other metals. I have put a theory forward to almost all the cryo researchers that I talk to. It comes out of looking at the metallic bond as if it were a chemical bond. I got this idea from reading some work by Dr. Mark Eberhard (Colorado School of Mines). His work states (as I understand it, as I'm a mechanical engineer, not a trained metallurgist) that for each atom in a crystal structure there is a preferred distance it wants to be from the other atoms in the structure. If it is not at that preferred distance, the structure contains more energy than the preferred state. My THEORY is that as we reduce the temperature of the crystal structure, we reduce the energy available to the atoms to be "out of place". By warming the part back up slowly, we do not put that energy back in, so the crystal structure is more perfect.
Please realize that this is stated in pretty simple, lay-man's terms. I have put this THEORY in front of a lot of metallurgists, and either they were being pretty polite and not laughing out loud, or they really did think that it should be investigated. I invite people to comment on this or other theories. This is the only way that we will be able to direct what few research dollars that are spent on cryo to the best possible experiments.
Hmmmm. I'm gonna be back at "my old school" next month, I'll ask a few of my old proffs what they think of the atomic spacing theroy.
FWIW: perfect crystals are amazing, IIRC the UTS of a ideal Fe-xtal is around 600ksi. These xtals dont exist in any but whisker forms. (too many dislocations exist above abs. zero due to thermo/kinetics laws {entropy})
Hmmm. had a thought, entropy is directly related to temperature only, so that cant be changed by a cycle to cryo temps and back since each degreee out (in cooling) has to go back in (during warming). What energy is not going back into the structure during the warmup? (i dont know, time to check the thermo books.)
nick
Any and all help in resaerch would be appreciated.
Thanks.
