Brushless Motor ( 24 to 90 V ) --20 to 200 watts
I am looking for Brushless motors to be used as 3 phase Voltage generators to rectify the AC output to charge batteries, at low to moderate RPM (less than 3000 RPM and preferable lower).
Low cost is basically important.
Shape is immaterial, the power source will be Wind Mills or Small hydro Runners.
URLs,Web Pages, Phone numbers and addresses.
Thanks for your assistance.
Nando
Nando
RE: Brushless Motor ( 24 to 90 V ) --20 to 200 watts
Try POWERTEC website.They have a line of Brushless DC motors that might help you out.
GusD
http://www.thomasregister.com
and type Motors: Brushless DC under Product or Service, which will return 173 companies to approach to
Why not to use a 12 or 24 volt auto or truck alterantoror and then convert it to 220 V with a converter ?
Thats the way a friend of mine use it on small hidro power plant.
By this way you can get on the shelf or used product, and speed is not a main problem.
Such alternator run at the variable speed of the car's motor.
Pardal
