Vertical turbine well pump valving
I am designing a water plant that includes a vertical turbine well pump that pumps into a hydro-pneumatic tank.  I would like to hear recommendations as to the proper valving to include downstream of the pump (check valve, air release valve, etc.) and which manfacturers of this type of equipment are the best.
