Paraffin corrosion of 17-7PH
Does anyone have any information on the corrosion of 17-7PH by a hydrocarbon fluid called isoparaffins, specifically ISOPAR H made by Exxon? Is there any reason to assume the hydrocarbon fluid would be corrosive? I've been unable to find any information on this. The properties of the material don't seem to indicate that it would be a problem.
Thanks.
Paul
Thanks.
Paul
RE: Paraffin corrosion of 17-7PH
