Software for Tube in Tube in Tube Heat Exchanger
Hi all,
Yes they exist: Tube in Tube in Tube Heat Exchangers.
The product flows through an annulus and is heated this way from both sides.
Does anybody know/have software available to do calculations on capacity, prodcut outlet temps etc. depending on heating fluid flow and temperature?
Many thanks for suggestions,
MVD
RE: Software for Tube in Tube in Tube Heat Exchanger
the calcs are straightforward for these type exchangers (i.e. Q = m x Cp x dT for both process streams and Q = U x A x LMTD - overall exchanger).  recommend investigating brown fintube or using the www search engines for double pipe exchangers.
have Fun!
-pmover
